Ir para o conteúdo principal
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Perguntas Visualizar todos
Battery light on but battery tested ok
The light goes out after the 5 minutes driving?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Thanks , it was helpful!
por
Adicionar um comentário
2 respostas
Solução escolhida
The "Battery Light" really is telling you the electic power to run the auto is coming from the battery and not the alternator. Check that.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have th3e same problem. The battery tests at 12.6 V and alternator tests at 15+ volts at the battery posts.
por
Pergunta mais útil
crowder451, if your getting 15+ volts when warm, that is pretty high and regulator may be faulty, check the attached link for good info. and trouble shooting charging system.
http://www.aa1car.com/library/charging_c...
Pontuação 2
1 comentário:
My light stays on for at least 5 mins when i slow down the light goes out..what could it be
por
Adicionar a sua resposta
Bill será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 5,999
