Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
4027 Perguntas Visualizar todos
I do I need to replace my phone's LCD?
Hi all,
My phone screen randomly started doing this the other day (although it had been dropped a few hours before that). As you can see, half the screen has a grey tint, and sort of artifacts begin developing after 30 secs.
My question is this: do I need to buy a new lcd, or is it worth cleaning and reseating the cables for my current one?
Thanks!
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
3 respostas
Since you did say it was dropped before your screen started to act up i would say that now your screen is on its way out. Which means that pretty soon it will eventually black out or wont work at all so yes you should get your screen fixed as soon as you can
Esta resposta foi útil?
Pontuação 0
If you open that and reconnect the connected. It may be fine.
Worth to try
Luck
Pontuação 0
Hey everyone, just an update here:
It started to gradually worse, as Justis warned, so I ordered a new lcd and that's solved the problem. The old lcd had a big bend in it under the grey part, so I guess that's what caused the damage. For anyone else with a similar problem, you have a warped lcd which will have to be replaced!
Pontuação 0
Adicionar a sua resposta
Harry Evans será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 63
