Ir para o conteúdo principal
Why is my transmission failing to shift after 30 mins of running.
I have a 2004 honda accord ex. After the car runs for thirty mins, the car will not shift out of first gear, when it is an automatic transmission. I have replaced the solenoid switch and the computer and problem continues to persist.
Esta é uma boa pergunta?
Pontuação 2
3 comentários:
Hello Prentice, How many miles are on your transmission?
por
I hace the same problem in My accord I have spent a lot of Money and the continiu....
por
Somebody can helo me .......
por
Adicionar um comentário
2 respostas
Check out this web page to help you trouble shoot, there is a ton of good info. http://www.hondaproblems.com/trends/tran...
Esta resposta foi útil?
Pontuação 0
Generally this is a sign of low or over-used oil.
I would check the oil level and its color first.
If you can do this, the trans oil should be a red color. If it is not, get it change ASAP.
Pontuação 0
Adicionar a sua resposta
Prentice Walker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 1,149
