Ir para o conteúdo principal
Pergunta encerrada
Printer makes me restart every time I want to print.
The error message "016-302" began popping up on the mini-monitor on my printer. I have to restart, then I'm lucky if I get to print one job before the same message pops up and the printer has to be restarted again to print. If I don't have anything to print, it will automatically default to "Restart printer" mode after a minute.
I ran the troubleshooter option, but it couldn't identify the issue. Anyone have any ideas?
Many thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try downloading this driver and installing it, by doing so it should reset the program and start fresh
Hope this helps
http://downloads.dell.com/printer/2150cd...
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi Nick,
Thank you for the prompt response. I downloaded the driver but I'm still having the problem. Regardless, I appreciate your suggestion. It was worth a try!
por
Since the new driver didn't work, it is most likely a problem with the printers logic board. You might just have to resort to getting a new printer.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 314
