The fan is at 0 RPM.
My fan had suddenly stopped working (I think), and it showed 0 RPM in all diagnostic apps, but fan diagnostics say that the fan is working normally. Still, I replaced the fan with one I bought on eBay, used but apparently tested. Nothing happened. It still shows 0 RPM and the fan isn't rotating. Temperatures go high and it slows down (Mac) or shuts down (Windows). So, do you know if it could be any software problem, or logic board problem, any way to test it? This is really annoying as I can't use it for multitasking at all.
PS: Resetting SMC didn't help.
Thanks.
Esta é uma boa pergunta?
4 comentários
What was the diagnostic tools you used to see what was happening?
por Dan
iStat Menus and SpeedFan
por carnnc
I've had problems with iStat in the newer systems. You may want to give TG Pro a try. But you do need to make sure you remove the others first.
por Dan
I was wrong, it is TGPro. Speedfan was the one in Windows which btw didn't even recognise the fan.
por carnnc
