Ir para o conteúdo principal
Apple iPad da primeira geração, disponível nas versões Wi-Fi e 3G com 16, 32 ou 64 GB de armazenamento.
266 Perguntas Visualizar todos
Wifi Logic board in a 3G Ipad?
I have an original Apple Ipad 1 WIFI that im pretty sure has a bad Logic Board. When plugging it in the screen flashes for second and nothing else happens. Ive tried doing the resets, and everything else and I think its just a brick. Ive found WIFI only logic boards on Ebay for $35. My question is can I install a Wifi only Logic Board into an Ipad that has 3G with Wifi in it? Would there be a problem fitting it in? Are the logic boards different shapes and are there cables in the housing of the 3G that have to be plugged in to work? Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
You Can but you will also need to buy a wifi screen too because of the antennas thats attach on the frame of the 3g Screen you will also will have to get rid of the sim tray flex
I guess you can keep the same screen just tape the antennas so they dont move around.
Esta resposta foi útil?
Pontuação 0
1 comentário:
So I cant just use the same 3G Screen I have now?
por
Adicionar a sua resposta
nickc75 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 135
