Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Samsung galaxy s6 earbuds one side not working
cant explain it very well so im going to show you
could you show me how to teardown the bud?
Esta é uma boa pergunta?
Pontuação 17
12 comentários
Before you go tearing it apart check to see if your getting it plugged in all the way if you have a case sometimes the case will keep it from plugging in all the way
por
I got the problem to did you fix it?
por
Mine right bud has very faint audio, basically the same issue.
por
ive got the same problem the upper speaker wont work plzz anyone
even if i plug it all the way no result
por
hi there
i am just wording could anyone help me i have a pair of Samsung s6 earphones and one is not working can anyone help me asap i really needs them
thanks
por
Exibir mais 7 comentários
Adicionar um comentário
20 respostas
Pergunta mais útil
Sounds nasty but i just blew and sucked the main speaker and they sounded great again!!
Esta resposta foi útil?
Pontuação 12
13 comentários:
Not for me...
por
me either ..
por
it worked for me!
por
This was crazy helpful. I thought I was going to have to buy new earbuds!
por
Worked for me. Alternating between blowing/sucking for 30-ish seconds and they work like new again.
por
Exibir mais 8 comentários
I just blew into the hole and it just fixed it somehow.
Pontuação 3
I just blew and sucked the main speaker.. works like a charm
Pontuação 2
3 comentários:
Blow and suck and main speaker for 10-20 sec each while alternating. It works for apple earbuds to for future reference
por
i could not for the life of me get this stuff stuck in my earbud out by doing that
por
nevermind i kept trying and it finally worked
por
The earbuds are made of molded plastic pieces glued together, and attempting to disassemble it would most certainly render the headphones beyond repair.
The jack on your phone doesn't seem to be an issue, since part of the earbud is functional.
Unfortunately, you will have to buy new earbuds.
Pontuação 1
the right ear phone is not work
Pontuação 1
1 comentário:
Same help me fix pls
por
I have two of these earphones and both have weaker or no sound in the right bud. It appears that everyone else has a problem with the right bud as well, and I find it odd that the same bud gets broken with everyone. Im convinced that the earphones themselves are quite bad on the right bud and somehow easier exposed to damage.
I still have my earphones from the galaxy s4, and they work just fine despite being old by now. You'd think new models would be less fragile, but I sit here with two pairs of new, broken earphones, and one pair of working old ones...
Pontuação 1
1 comentário:
Same with mines and i got them with my s8. Akg ones. Rigth one has faint audio
por
Blew and sucked my earphones. And were perfectly working.
Pontuação 1
I trid a combination of both the blowing and suucking aswell as using a toothbrush to try and get in the holes to clean them if that was the case and it worked for me
Pontuação 1
I have same problem plz help me
Pontuação 0
Get a lighter and go over the part With no sound this helped me
Pontuação 0
2 comentários:
it do not work
por
last time i did that i was trying to melt// burn of the wax, ended up with my earbud catching fire, even tho i did fast passes. Not recomended, seeing as it is highly dangerous.
por
How do you fix this problem
Pontuação 0
1 comentário:
por
I can hear not sound from both earbuds
Pontuação 0
Its really easy to fix it i had the same problem one side didn't work so just clean it from inside alright by the time you use the earbud it gets dirty :D so just search how to open it safely and clean it maybe with a tissue paper
Pontuação 0
I found when I took my earphone for when I had this problem It was impossible to put it back together.
Pontuação 0
I need help. My earphones is making no sound when plugged in, but when i move the cord around it starts to make a static noise. Plzzzzz help
Pontuação 0
How do you make the sound come back
Pontuação 0
The part of the speaker that doesn't work blow on it or keep blowing on it for 30 seconds.
Pontuação 0
my left side is working the my right one with the microphone does not work at all.
Pontuação 0
This problem is usually caused by wax blocking the holes in your earbuds. You can use a sewing needle to poke through the holes in the speaker when the headphones aren't in use and you're good to go. The sound will be just like new again!
Pontuação 0
My left side just won't work anymore..
Pontuação 0
Adicionar a sua resposta
lukasgreicius70 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 62,539
