Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
542 Perguntas Visualizar todos
No Power, #1 LED Stays lit, #'s 2&3 LED's flash
I have an Intel iMac 20", Model A1224, 1gb RAM, that one day just stopped turning on. I opened it up and checked the diagnostic LED's on the board. #1 stays lit. #2 and #3 blink on and off. #4 doesn't light up at all.
When I press the power button on the back of the black, plastic case, the internal fans will attempt to spin, but will not spin. (They rotate *maybe* one (1) degree out of the 360 degrees they would spin.) I can hear a high-pitched sound--kinda like a whirring sound--coming from the power supply when this occurs.
I have attempted to reset the SMC with, seemingly, no effect.
Any advice would be much appreciated.
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
I have the same exact issue. Replaced the power supply and 2&3 are still flashing. Did you find out the problem?
por
Adicionar um comentário
2 respostas
Solução escolhida
The blinking indicates a RAM problem. First reseat the RAM. If that fails try one stick at a time in each of the slots.
Esta resposta foi útil?
Pontuação 2
1 dos comentários:
Excellent low cost suggestion. +
por
Seems that the power supply has gone. #1 LED indicates trickle power, it's always on when the computer is plugged in and supplies 5V to the logic board. Whe #2 and#3 are blinking it means that CPU and GPU can't be initialized. Usually a (don't know the english term for it, i try ;-)) power store diode is gone on the power supply. You can check it but be careful. Leave the machine unplugged for at least 24H cause the capacitors can store a lot of voltage.
Good luck.
Pontuação 1
2 comentários:
Installed a new Power Supply. #2 and #3 LED's are still blinking. Any other thoughts? Thanks.
por
I have the same problem. I also changed power supply and the problem still there. Any answer?
por
Adicionar a sua resposta
Plumberman010 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 3,061
