Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Why won't iPhone restore?
I was expeencing some problems, so I thought I would restore my phone. The proces was going smoothly, and then when it finnished, it came up with an error that said
"There is a problem with your iPhone.
Please visit the Service Answer Center to find answers to all your questions about service options, warranty and other processes in your country.
To find your nearest Apple Store, click here."
Any ideas?
Esta é uma boa pergunta?
Pontuação 3
2 comentários
when you power your phone on, it shows a small blue "i" on the bottom right corner.When you click it, does it show a IMEI Number or is it blank ?
por
theres no "i"
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Try placing the phone into DFU mode then try a restore in iTunes again.
Do the following in sequential order straight after each other.
  1. Plug your device into your computer with a USB cable.
  2. Turn off the device.
  3. Hold the Power button for 3 seconds.
  4. Hold the Home and Power buttons for 10 seconds.
  5. Release the Power button but keep holding the Home button.
  6. After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
Let me know how you get on.
Esta resposta foi útil?
Pontuação 1
4 comentários:
I tried that, it just has the same problem
por
Are you trying to restore to a particular version of iOS?
por
no, I would just be happy to get it to work
por
Try the restore process on another computer, i've had an issue like this before which turned out to be a problem with iTunes on the particular computer I was using. Try using a friends / family members computer.
por
Adicionar a sua resposta
Ben Russell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,286
