Ir para o conteúdo principal
Pergunta encerrada
Why is my LCD not working after screen replacement? But backlight is.
Hello!
I cracked my screen, bought a LCD replacement, and replaced the screen. After trying my phone again, the screen was all black but the backlight works. The screen also shows weird white blocks when I get a notification.
I tore (what I think is - after some research) the "home button cable." The cable on the bottom left part of the silver shield.
Is this what is causing my LCD not to work? Or is my replacement screen a dud?
Please let me know what replacement I need to order, and if I'll need any other tools besides the original that came with my replacement screen! Also, if my touch ID will still work. :)
Update (11/12/2015)
Update.. I put my old, cracked screen back on and everything works perfectly except, of course, the home button because I tore that cable. I took my phone to techshell and the lady said the replacement LCD is bad... So I am going to order another and see if it works.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Ok, wow. So the backlight working but nothing else should be curable, by a force restart
How to Force Restart an iPhone 5
The white blocks just mean you didn't do a good job of securing the digitizer cable. As far as the home button and Touch ID is concerned. They are lost to you. At least for now. I heard some of the veteran techs are working on this. But, I haven't heard anything about it yet
Esta resposta foi útil?
Pontuação 1
5 comentários:
I've tried this before. I just tried it again... no response
por
so by ripping the bottom of that cable, that just mean no home button?
por
Weird. That should help with your issue. Unless the part is bad. Yes. You'll never get the Touch ID back. However you can put another home button in and it'll work as a home button. Just no Touch ID
por
So what do I do now?
por
I guess try putting it into dfu and then... Oh wait, you can't. You don't have a home button, right now... Crapola. I'm running out of ideas
por
it's possible the digitizer cable isn't connected properly, I'd say unhook the assembly and re-hook it. if that doesn't work, try unplugging the battery from the board, and plug it back in.
it's also possible (maybe?) that the digitizer cable got torn during assembly, and it's not always easy to see the tear as the smallest nick in the wrong place can cause it to go bad.
Pontuação 0
That is a common symptom of long screw damage. If the screws covering the connectors are put back in the wrong spot.
(Credit info below to www.http://mendonipadrehab.com/) if it is indeed that get ahold of - @jessabethany
iPhone 6 No Backlight after simple screen replacement:
An iPhone 6 comes in to a shop for what seems like a straightforward screen replacement. However, the new screen does not light up.
After component failure was ruled out, this phone found its way to my microscope.
I confirmed the phone was turning on, but showing no display--not even on an original iPhone 6 display. This seemed to be a straightforward backlight repair. Raise your hand if you know what component(s) should be replaced to solve a standard backlight failure in this situation? If you said "the coil" or "the backlight ic" punch yourself in the face and read Backlight 101.
Given the history, those of you who read Backlight 101 will recognize that this will most likely be connector damage or a bad backlight filter. I have repaired a backlight from a water damaged iPhone 6 before, so I'd already mapped the backlight filters.
I opened the phone and found very minor damage at the edge of the LCD connector, but all the pins intact. I believe the connector is okay. I uncovered the backlight filters and found that they showed no signs of damage, and had continuity as normal.
I even used my new FLIR One infrared camera to make a heat map comparing this iPhone 6 to a normal iPhone 6. Spot temperature measurements were largely the same. No hot spot, so therefore no short circuit.
Since the history tells us the display was working fine after the drop and before the screen change attempt, what could be the problem?
Making a connection to the recent BSOD problem on the iPhone 5S, I took a hard look inside the screw brackets. In a normal phone, the bottom of the screw bracket is nothing but the clean black coating of the solder mask applied to all non-conductive surfaces of the board. Sometimes you can see blue plastic along the edges of the screw bracket from the plastic coating on the shaft of the screws.
Pontuação 0
1 comentário:
My backlight is working but no display. How can it be long screw when I didn't place any screws back in the phone. I replaced my battery now my phone display will not work. I have tried 5 screens, all the same thing, backlight no display. please help?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 928
