Ir para o conteúdo principal
Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
23 Perguntas Visualizar todos
engine dies when throttle applied
Why does my engine snuff out when I apply the throttle
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Pergunta mais útil
Possibility it may have old gas or some water in fuel.change in-tank filter and adjust mixture jet located (opposite side of throttle cable a hole with small flat head screw). Play with it a quarter turn in either direction to see any changes.our echo techs say they call it bubbling. A unique sound youll know right away when you get it adjusted right. Do this at idle. If the adjustment brings the idle up no worries turn down the idle screw at the top of carb.good luck
Esta resposta foi útil?
Pontuação 3
Dies out when throttle is applied
Pontuação 1
I have had this problem too. Mine was too much carbon build up. I took the muffler off and used a propane torch to clean the screen and the inside of the muffler.
Pontuação 0
Adicionar a sua resposta
murrayoshea2 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 64
Duração total: 15,944
