Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Won't charge battery, magsafe stays green.
I run a small computer repair shop and have done hundreds of repairs in practically every version of every Apple computer but this one has me stumped. Customer came in and the computer laptop would power on and everything would work except the wifi and the fan was on full blast constantly. Very annoying.
I popped it open to find that the previous shop working on this computer LEFT THE HEATSINK OFF THE CHIPS! Since the computer still worked I powered it down, ordered the heatsink and installed it. When I got everything back together the magsafe no longer lights up for more than 2 seconds if at all. I removed the dc-inboard and gave it an alcohol bath and re-flowed the solder and now it lights up, but stays green and doesn't actually charge the battery. I'm completely bewildered and would appreciate any help or diagnostic steps!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
reflowed what? What does it say with a known good OEM 85w charger attached and battery connected? battery not charging, or an X on the battery?
Esta resposta foi útil?
Pontuação 3
3 comentários:
I reflowed the solder in the DC board. The laptop does not lower up so nothing shows on the screen at all.
por
Get a new dc in board, these things are five bucks. Try turning it on by shorting SMC_ONOFF_L to ground. What voltages do you get for PM_SLP_S4_L, PPBUS_G3H, PP3V42_G3H, PP5V_S5, PP5V_S3, and PPVRTC_G3H?
por
Hello @zzz. I unfortunately don't have a schematic. Any advice on where I'd be able to find one?
por
Adicionar a sua resposta
amer jarrah será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 358
