Ir para o conteúdo principal
iPhone has no mic access or sound at any time, when interacting.
Hey there I have an iPhone 5 that has a fault with the mic and speaker while in a phone call and video's ect.. I have tried changing out all the hardware (put the logic board in a perfect working order iphone5) which made no difference, which suggests its a problem with the logic board or a software problem.
When trying to activate siri I receive a message titled "Built-in Mic Not Active"
Was wandering if anyone had come across this before or knew a fix for this issue.
Cheers,
Chris
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Sounds like maybe you have cancelation microphone sensor...2nd mic which is connected to your power/volume flex...if you cancelation mic is damaged or cloged it will cancel out all sounds.
Esta resposta foi útil?
Pontuação 0
Comentários:
I did switch the logic board out from the hardware though, I put it into a perfect working chassis and the problem was still repeatable. This wouldn't be the case if the mic itself was damaged?
por
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 44
