Can the charging port be replaced?
The port that you put your charging cored into on my Nook Glow Light has a broken pin. Can it be replaced?
Esta é uma boa pergunta?
Pontuação
0
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 206
Probably. If you can open your device so that you can see the port and then search on Ebay for micro usb port. Then match up yours to one of the many different styles available. They are all quite cheap. Then its a case of unsoldering yours and soldering on the new one. Thats what I would do. If you don't think you have the equipment to do that scale of soldering then a local phone repair shop should be able to help you out.
por martin nash
