Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
954 Perguntas Ver todas
front of iPod hot after replacing battery
I replaced the battery in my iPod classic but as soon as I reconnected it to the front of the iPod, the front of the iPod became very hot. Should that happen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
Visite Nossa Loja
2 Soluções
Resposta Mais Útil
paigeandersonmcdonald, always double check your work. Make sure the battery flex is properly seated. Be careful and double check the battery connector. It does have a tendency to break of the board. If it has come loose it is possible that you are shortening out the battery.
Esta resposta foi útil?
Pontuação 1
Comentários:
I am a total novice at working with electronics , so I'm not sure what I'm looking for but nothing appears loose and the wiring seems to be as far in as it can go. Still every time I retry the front still gets hot
por
Try with another new battery and see what happens. If it still gets hot you are having issues with the logic board.
por
usually that is from it not being seated into the socket completly
Pontuação 0
Adicionar a sua resposta
paigeandersonmcdonald será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 53
