Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Perguntas Visualizar todos
itunes won't read my iPod.
My computer reads it as a portable device, but itunes will not read it. Also, my ipod says that there are 0 bytes left for storage, yet it says there is no music, photos, or anything. It's filled with 'other'. What do I do?
kalena
Esta é uma boa pergunta?
Pontuação -1
4 comentários
how do i go about doing this?
por
First of all, here´s a manual how to open and how to remove the hard drive.
iPod 5th Generation (Video)
the needed tools can be found here.
http://www.ifixit.com/Tools
And last but not least, you will need a 1.8"h ZIF to USB adapter.
http://cgi.ebay.co.uk/Toshiba-1-8-ZIF-LI...
por
my ipod finally synced! however, it'll sync a few songs and then itunes freezes and wont shut down until i disconnect my ipod. i've restarted my computer and used different ports and it still happens. now what?
kalena
por
What have you done to get the iPod to sync? I still suspect the hard drive being damaged.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
you should first try to restore the iPod. If that doesn`t help, tell us and we will help you from there.
Esta resposta foi útil?
Pontuação 0
2 comentários:
it wont restore. when i reset it, thats when the ipod said memory full yet no music ect was on there. when i try to go to My Computer and click on the ipod pic the computer freezes. what do i do now?
por
Sounds to me like an issue with the hard drive or its cable. If you are willing to try, open the iPod and use an adapter to access the drive directly via USB. If the drive can be accessed normal this way, i would tend to a damaged hard drive cable otherwise its the hard drive itself.
por
Adicionar a sua resposta
kalena clarkson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,123
