Ir para o conteúdo principal
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Perguntas Visualizar todos
Pergunta encerrada
Replaced Screen and Digitizer - Now Home and Back Button Don't Work
I just replaced the screen and digitizer on my Note 3. This is my first time doing anything like this. The screen works and is responsive for the most part; the home and the back button are not working. The turn-on button on the side works when I press it really hard. Did I not put it back together properly? Why isn't the home and the back button working?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello!
Iyou need to check to see if the flex is wrong connected, because the best is what could happen, if not that, then the screen came damaged.
Luck!!
Esta resposta foi útil?
Pontuação 1
2 comentários:
How do I know if the flex cord is connected properly?
por
look at the cells of the connector and check you are well and you can do it also with a multimeter measuring watts!
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 96
