iPod classic battery replacement
Where in south Jersey can I get my iPod repaired. I believe it is just in need of a new battery since I get absolutely nothing when I charge.
Esta é uma boa pergunta?
I dunno if you're feeling savvy. You could try this
iPod Classic Battery Replacement
Using this
If this sounds like it's too much for you, it probably is. There's nothing wrong with that. A simple google search, could help you get in the right direction, of finding local repair shops in your area. You may have to try a few times, before you find the right one for you
Esta resposta foi útil?
Try www.Iresq.com
(That's "I rescue" being cute)
Phil
BTW if you try it yourself using one of the Youtube videos, you need to be aware that the ipd Classic 6 is a thick battery and the Classic 7 is thin coz it's a thinner case
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 223
1 comentário
It's a bear to open. Once it is open the rest is easy. So, if you are going to repair it by using the guides, do not get discouraged. Use a good putty knife and have at it.
por oldturkey03
