Ir para o conteúdo principal
The iView SupraPad 776TPCII is a 7" touch screen Android tablet.
8 Perguntas Visualizar todos
Why won't my device turn on?
Tablet is unresponsive when I press the power button.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
730TPC if i turn on is shown searching always never allow me to turn off. or seen anything on screen unless iview
por
This iview will not turn on I bought it for my daughter for Christmas so I decided to check it out it will not turn on
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Generally, this question is caused by broken battery or broken button. Try to connect it to any device and see if there is any response. If yes, there may be some problem on your power button, else, your battery should take responsibility. You can check the Replacement Guide part and follow the step to replace your broken part.
Esta resposta foi útil?
Pontuação 2
I have a new iview laptop will not turn on at all
Pontuação 0
1 comentário:
It’s brand new just started it up and then started dL ing and then turned off and will not turn on
por
i have a iview tablet it turn but only where its says reboot please help me
Pontuação 0
My iview tablet screen broken and won't turn on
Pontuação 0
The iview was just fully clean by resetting it
but it’s not showing anything after the iview logo. The screen remains greyish
Pontuação 0
1 comentário:
What todo with this I had to reset it because
I forgot password
por
Adicionar a sua resposta
Cory Gratzer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 11
Duração total: 1,849
