Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
128 Perguntas Visualizar todos
Broken antenna connection on logic board, how to fix?
So I bought a phone that was previously repaired and the guy tried to fix it but it looks like that he broke the antenna connector on the bottom board and on the logic board. The bottom board is easy to replace ($20 on ebay) but I'm not sure how to replace it on the logic board. I can't seem to find anywhere that has that circular piece online so that I could get a repair shop to solder it back on. Is there another way to fix this? Could you solder the antenna onto the broken connector and still get it to work?
Here are some pics
Bottom connector (totally ripped off) ($20 replacement on ebay)
http://i.imgur.com/Jfz2hwD.jpg
Top connector on logic board, it looks okay but I think it's a bit bent/ripped off or something because I can't seem to get it to stick back on. Is it possible to solder it right onto that connector?
http://i.imgur.com/TyenDEk.jpg
And here is a pic of that rear of the phone
http://i.imgur.com/SPN7Pgq.jpg
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
2 respostas
Pergunta Mais Útil
You can buy the antenna connectors but not sure if they are standard for all phones. http://www.aliexpress.com/af/antenna-FPC...
Esta resposta foi útil?
Pontuação 1
I have the same problem... Could you fix it?
Pontuação 0
Adicionar a sua resposta
Max M será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 4,910
