Ir para o conteúdo principal
A Nikon Coolpix S4100 é uma câmera de 14 megapixels para fotos e vídeos, com zoom óptico de 5x e tela LCD com controle por toque.
How do I adjust the camera's resolution?
I'm having trouble adjusting the resolution for the camera in different environment settings. Do you know how to adjust the resolution for the Nikon Coolpix S4100 camera?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
To change the resolution for different environmental settings,
  1. Select the button to the right of the screen with a camera icon labeled: scene.
  2. A menu should appear onscreen, select the second option in the center labeled: scene mode.
  3. Choosing one of the options listed will change the resolution and camera settings for specific environments.
I hope this answers your question!
Esta resposta foi útil?
Pontuação 2
1 comentário:
All I need 2 know is: What is the highest icon resolution when taking a long distance shot? ...Is it the Parthenon Icon?
I need to upload a minimum of 970 pixels wide x 420 high!
Can the Camera support/ create that?
por Compartilhar
I had the same problem , I found that if went to the camera settings and scrolled down to the reset all button selected that and then the megapixel size options were selectable again. Hope it works.
Pontuação 2
I am doing this and the megapixels are not changing.
Pontuação 0
Adicionar a sua resposta
Haley Heikkinen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 5,445
