Ir para o conteúdo principal
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
207 Perguntas Visualizar todos
How do you fix a Kenmore 18" stand fan?
My Kenmore 18"stand fan has stopped working.At first you would turn it on and it would just turn slowly but now it just doesn't turn at all. I want to fix it because i've only had it 1 month plz help
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I had my Kenmore stand fan for 2 months before it died. We noticed that the plug said extra fuse and opened it, there was no fuse and no store in our area carries the size, amp, or volt we need (2.5 amp, 125V). Now I am on a hunt for the fuse online. Good luck.
por
Adicionar um comentário
3 respostas
Solução escolhida
I'm sure it is covered under warranty, return it and get one that works.
Esta resposta foi útil?
Pontuação 1
2 comentários:
There is only a 30 days warranty and return on these low price items.
por
The Kenmore warranty site states that it is one year:
https://www.kenmore.com/warranty-informa...
por
Pergunta mais útil
Dirt. You need to clean and lubricate the motor bearings. Try the front one first, just behind the fan blades. WD-40 may work for a while, but the best fix is to disassemble and clean the bearings well.
Pontuação 2
What about the fuse could it be a problem to or it is the moto bearings I only got it for a month I took it to jamaica for my mom.
Pontuação 0
Adicionar a sua resposta
Briana Alexandre será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 21
Duração total: 5,633
