Ir para o conteúdo principal
This is the first generation of Amazon Fire TV (model CL1130), released on April 2, 2014. It is a powerful media streaming and gaming device that allows the user to stream digital audio/video content to a high-definition television as well as play video games.
33 Perguntas Visualizar todos
Why can’t I get internet access with a wired Ethernet cable?
When I try to connect to the internet using a wired Ethernet cable connection, the Amazon Fire TV will act as if there is no internet connection. What can I do to fix this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
There could be a couple reasons for the Internet connectivity problems. Maybe the Ethernet cable is not correctly connected, or the router is not providing Internet access. Maybe it's also a hardware problem, in which the Ethernet input port may be damaged. For more information, visit
Amazon Fire TV Troubleshooting
Esta resposta foi útil?
Pontuação 0
3 comentários:
useless information. how is this solved ?
por
I use the Amazon Cube 2nd Gen. When I connect ethernet Have to cut off Wi-Fi The problem that I have I cannot use my Amazon echo's Because when I cut off the Wi-Fi on Amazon cube It disable everything else So I have to use either or
por
Hasn't solved my problem must be problem with new fire stick
por
Why won't my internet is not working what is going I have xfined
Pontuação 0
Adicionar a sua resposta
cory burke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 14,307
