Ir para o conteúdo principal
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
520 Perguntas Visualizar todos
engaging handle is stuck and will not go up to engage blades
try to raise handle to engage blades but will not move , mower runs but blades will not engage
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Is the blade engaged by magnetic switch or by belt clutch. If its by magnetic switch check to see that there's power getting to the switch . If its engaged by belts check to see if the belt is moving when you move the lever or if the lever mechanism is broke .Check the belt has it come off?
Esta resposta foi útil?
Pontuação 1
the belt looks on but is loose
Pontuação 0
Comentários:
Not loose piece that is plastic on end of handle is broke
por
Adicionar a sua resposta
jon hulme será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 3,978
