no display on the screen
only voice will come on but no display on the screen. its blank white. should i send it to apple store?
Esta é uma boa pergunta?
Try a hard reset. Press and hold power power and home button at the same time for 10 seconds. If that doesn't work it may need to have the lcd cable checked or logic board repair. You can also try the Apple Store but I doubt they will be of help unless it is still under warranty.
Esta resposta foi útil?
thanks guyz...have tried everything suggested, its still hopelessly white blank screen, just wont shut down... will take it over to some shop locally here...else send it over to the apple store... thank you all!
I had the same problem. Hard reboot worked for me. Thanks!
Did you tried to restart the iPad? you can try below steps before send it
More info,
no the voice continuously goes on at the back, and i cant switch off the ipad no matter what i try...
no red slider comes up, only the voice and blue boxes will show up, i try to slide there but i cant, voice makes the blue line boxes move on. i tried to switch off from the main button on top too but it wont shut off
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 412
