What dose this mean
my i pod will not turn on it shows a piture of another i pod frowning and tells me to contact apple support
Esta é uma boa pergunta?
Dead or loose hard drive. Could also be corrupted firmware.
Listen to the drive. If you hear it click, the drive is bad. If it isn't clicking, try and restore the iPod in Disk Mode. To do this, you reset it by pressing the center and Menu buttons in, and then pressing the center and Play/Pause buttons in. This will put it into Disk Mode to restore it. If this doesn't help, look at the drive and cable possibility again. Replace the drive, then the cable. The cable isn't the fault, in most cases. These use a platter drive, and are bumped around on a regular basis. It's usually the hard drive.
Guia
Nível de dificuldade:
Moderada
30 - 50 minutes
Guia
Moderada
20 minutes - 1 hour
Esta resposta foi útil?
Hi
1. first Try to Restore The ipod with itunes in Disk Mode
2. Get a HDD Flex cable and change it (sometimes this flex is damaged)
3. HDD is Dead try with another one its important the same capacity
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 804
