Ir para o conteúdo principal
The Pentax K200D is a 10.2-megapixel digital single-lens reflex camera released in January 2008 with the higher-end K20D camera. It was discontinued in December 2008, making it one of the shortest-lived DSLR cameras.
5 Perguntas Visualizar todos
battery power indicator flashing outline only
When switching on, battery indicator flashes with outline only, camera not operating. Same thing with new batteries.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
In the past I have found that you could clean the battery terminals, both at the bottom of the battery bay and on the battery lid with lighter fluid and a cotton swab and get the camera up and running, but the cleaning fluid needs to be lighter fluid as alcohol didn't do the trick for me ... AND the type of battery is pretty critical too, as regular alkaline batteries do not have sufficient current to do the job, I use the Energizer Ultimate Lithium battery and coat the ends with dielectric grease (just a dab/small amount) ... I have had some success using this described method ... thank you, good luck ... Jim Nickerson, Pentax user and repairer ... 8)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
braynosma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 932
