Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36 Perguntas Visualizar todos
Screen went black, Apple Icon off
Why did my screen go black? I can see the screen when the computer is placed in direct light.The Laptop still works fine
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Either your inverter board or the LCD backlight has failed. Guide to replace the screen is here. You should be able to locate a reasonably priced screen assembly, since a lot of those machines have dead logic boards. I recommend checking eBay.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thank you so much bro! I had a feeling is was one of the two you mentioned. Do u know how difficult it is to replace? either one... I am mechanically inclined.
por
Here is the inverter and here is the LCD Panel.
por
The iBook range is not really easy to repair. If you're not feeling up to it, it's better to take it to a professional or find a skilled mate.
por
thank you all!
por
Adicionar a sua resposta
copper Wiezi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,186
