Ir para o conteúdo principal
This Power Mac G4 has Mirrored Drive Doors.
80 Perguntas Visualizar todos
Hard-drive not spinning up at ATA100. Need new LogicBoard?
Hello everyone,
I've got a MDD (DP 867 / 133MHz FSB) with a harddisk not spinning up when connected to the ATA-100 port. At the ATA-66 it spins up , but no target disk function / no boot up. When placed into an external hard-drive bay it works fine.
LogicBoard issue ?
If so ..
May it be possible to fit a FW800 LogicBoard (1474a) into a MDD with an installed LogicBoard "820 - 1380-A" ? Cutting out that port being compulsory . Are there compatible LogicBoards to fit in (eg. 820-1453a)?
Regards Jan.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Supplemental.
The system does seem to not respond to ANY inputs from keyboard, caps lock not working, fans speed up, heat-sink get warm after some time.
por
Adicionar um comentário
2 respostas
Solução escolhida
Try double checking and exchanging the HD ribbon cables.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Good to see you back. +
por
Thanks for your reply !
No change at all .. tried all ATA ports - disk spins up on the 33 and 66 ATA channel, and remains silent on the ATA 100. It even starts when cable is unplugged while the computer is running.
por
Will it start up from the optical drive? Insert disk & hold down "C" key. I have two of the dual 1.42. logic board 630-4643
por
I thought about this one >> http://cgi.ebay.com/ws/eBayISAPI.dll?Vie... <<
are all the boards (FW400) compatible to the 820-1308a? Do you've got a spare board for me?
por
All the mentioned steps would be helpful if only ribbon cable / harddrive or PMU error where present. This is obviously not the case here.
Closed.
Thanks for you contributions, much appreciated .
Jan.
Pontuação 0
Adicionar a sua resposta
Jan Bernert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,223
