Ir para o conteúdo principal
I can't use microphone in speaker and Siri
I can use my iPhone for recording voice notes, videos, shazam, calling with the phone in my ear, record voice messages in WhatsApp but when I try to make a call over Speaker or trying to use Siri, the michophone doesn't work. What can I do?
Esta pergunta é pertinente?
Pontuação 3
Adicionar um comentário
5 respostas
Pergunta Mais Útil
An iPhone 6 has 2 microphones, the one in the bottom is used for normal voice calls, shazam etc...
The other one is on the top next to the front camera (it is one assembly with the camera, sensors and earspeaker cable).
replacing that assembly could solve the problem.
Esta resposta foi útil?
Pontuação 1
Try a new front camera.
Pontuação 0
Comentários:
I tried and not working. My microphone does work on another device.
por
I had the same problem too. The store replaced my iPhone 6. Now after 4 months, the new replacement is having the same problem again. Maybe this is a mishap of iPhone 6 units.
Pontuação 0
Maybe the anti dust mesh is not lined up correctly...which means every time you install an new camera even though it's working it's being cancels because it's not aligned in the phone correctly..what I would do is take the screen out and take the camera and earpiece out and check and see if you could see both holes one being small and one being bit larger.
Pontuação 0
Comentários:
[image|690479]
I would check not only out side but inside to make sure it looks aligned
por
Example
Pontuação 0
Adicionar a sua resposta
Jairo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,082
