Ir para o conteúdo principal
Pergunta encerrada
Battery/ screen repair problems
Fisrt I am doing a glass replacement and I accidentally turned my phone on after disconnecting the screen, how do I turn it off ?.
2. I am still getting bubbles on my fourth time after reapplying the glue.
3. I am using a regular blacklight to dry the loca , how long should this take ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Josh
First: How do you know if your phone is turned on if you have no screen? In any case, just unplug the battery.
2. Are you using the same glass again and again or a new one each times?
Because loca is really messy and pratically impossible to clean at 100,I suggest you use a new one to be sure.
To minimize your bubbles you have to gently place your glass on your lcd. And by gently I mean the slowest you can. A spudger or dental pick my help as lever.
If the glass drop too quickly it will create a movement in the glue which will add air. Air in liquid = bubble.
Once your glass is place over your lcd, you can press in the center up to the edge to remove the excess of loca and at the same time you'll remove the bubble.
3. Between 15 to 30 minutes. I dont think you can over cure it. So more is better than less.
My final advice is : dont do loca. It's to unpredictable and i had a few of my screen that eventually stop working.
Max One
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thanks for your help, I am using new glass and was able to cure it on, but now I am onto reassembly, can I use a small amount of krazy glue on the frame ?
por
Yes it's possible but again I recommend against it.
The original frame was glued with a special hot glue. If you still have it, you may be able to reglue it if you heat you glass enought to heat the glue in the frame.
If you dont have it anymore, then it's possible to find a new one with this special glue pre installed. Check this link: http://www.phonefixpro.com/product-p/01-...
Max
por
I am also thinking of buying a new screen assembly and LCD if this attempt fails, what is the difference between the apple and generic LCD assembly's ?
por
The overall quality. The frame is better bounded, the glass is more resistant and the connector fits perfectly.
Lcd generic can be a good choice too, but you must make sure that you are buying the best generic quality. Because lower quality can have many problems.
You always have what you are paying for. Its up to you to decide how much you want to invest in your iPhone 6+.
Max
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 126
