Why is my watch not turning on?
Just a black screen won't turn on
When on charger only shows battery with lightning bolt. Help!
Esta é uma boa pergunta?
1. It might have happened because of your cord on your charger. I heard that some people had faulty cord, so first check the cord. If so then replace it with the ordinary ones.
2. Press and hold the button for approximately 25 seconds.
Hope this helped! ^_^
Esta resposta foi útil?
still my watch showing boot loader after pressing button for long period more than 1 min :(
I changed the original charger with my samsung charger and now it's charging.
I just brought it new and is not turn on
If the "lightning bolt" appears, the Moto 360 is good. Wait a while after it begins charging, then touch the screen while it is on the charger. A light ring around the border should appear with a percentage of the charge. As the percentage increases, the ring will be growing, until it reaches 100% and shows a complete ring.
If the ring or the percentage doesn't appear or never increases, then the battery isn't hlding the charge.
I brought it new and is not turning on
My watch won't charge and won't turn on either. Don't wear it that much and just over a year old. Was having problems with it charging beforehand, not sure which it is.
Can't get any live support thru Motorola, they recommend the website via chat. Only get redirected everytime I try there. Frustrated and turned off by their care of their customers. Any suggestions??
Hi, my name is Brittany. I also have a moto watch that wouldn't turn on, and what I did was I took the watch apart all the way, uncoupled the battery and took it out for 10-15 minutes and I reassembled the battery, put everything back together, and turned the watch back on by pressing the button on the side. It turned on straight away, and aside from needing a charge(it was at about 55% power), it worked perfectly!
But Brittany how did you take the watch apart?
IT works at me, thanks Brittany
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 50
Duração total: 30,232
5 comentários
My watch war on 75% and when i tried to reset it, it didnt turn back on...I need help. Plz
por Lamont
por Alex Sandraa
My moto 360 2nd generation's touch screen is not working …..please resolve the problem
por Shaikh Shanooo
My watch moto 360 the battery sign comes on but the watch still wont turn on
por Jesse Rosas
Press the power button for 15-20 seconds, and the watch will vibrate twice. Now your Moto 360 will launch into Bootloader mode (you may or may not see it as the display is black in colour). After 2 sec, simply press the power key again to exit Bootloader mode and power up the Moto 360 as usual
por Vignesh Ravi
