Ir para o conteúdo principal
Guides and repair information for devices that scan and save images, but do not print.
led light blinking red; error code 3006 ADF lamp error
Have googled this issue, cannot find the reason behind the problem. Definitely hardware, (not driver or connection as I have connected another exact same model to my computer and it works fine). If it is indeed a "lamp" or something else internal, I would like to know what parts and how to get them.
Model: HP Scanjet 3000 pro scanner
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
if you still have the scanner, then it sounds like sensor flag is stuck:
https://support.hp.com/lv-en/product/hp-...
https://h30434.www3.hp.com/t5/Printers-A...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
debbie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 2,167
