Pular para o conteúdo principal
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
277 Perguntas Ver todas
What can I do with a failed GPU?
Hi. A friend of mine gave me his old 2006 iMac (model A1207, EMC 2118). Its GPU is starting to fail, so I can't keep it running Mac OS X for more than 5 minutes before everything crashes. Since the GPU is soldered to the logic board the only solution would be a logic board replacement, but I don't want to spend ~100$ on such an old computer. I tried booting a CLI version of Linux and it seems to work fine without a GUI, however I don't find it useful at all.
Do you think there's still anything it may be good for or should I just tear it down for parts?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 Solução
Solução escolhida
Sadly, even though-breed classics like this one need to be put to pasture.
Given the limits of this system I don't think you get much for parts. Sorry
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jacopo Jannone será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 152
