Ir para o conteúdo principal
Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
20 Perguntas Visualizar todos
wii won't read sd card ios 37 problem
my wii won't read any sd card after i update ios 37 the problem not with sd card and not with the sd card reader the problem from softmode
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
I think you should format your console after backing up any important data. Please remove all external memory drives/cards before doing so and then start fresh. The most common cause of errors like this are a “stubbed ios” and d2x would be your best workaround. Make sure to reinstall ios149, 122, 121 and 132 when you’re finished getting back to the source of your issue.
Esta resposta foi útil?
Pontuação 0
same prblm, but my wii reads it, my pc doesn't
Pontuação 0
Adicionar a sua resposta
peshoking3010 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 329
