Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1695 Perguntas Visualizar todos
New USA Model CUH-1215A teardown?
Hi iFixit,
When do you expect to have a teardown of the new CUH-1215A PS4? I expect that it is similar enough, but I noticed that the HD screws are in slightly different locations. I would like to replace the thermal grease on mine as the fan is a little loud when gaming.
Thanks
Esta é uma boa pergunta?
Pontuação 7
17 comentários
I am looking to tear mine down tomorrow. I just purchased it and would like to apply AS5 and stiffen the clamp holding the heatsink against the APU
por
Cool. Take pictures and post your guide. : )
por
I'm needing a power supply and can't find any help
por
What type of power supply do you need? 4 wire or 5 wire?
por
I need a cuh1215a power supply can r commend where I could buy one or could I use a different model power supply?
por
Exibir mais 12 comentários
Adicionar um comentário
2 respostas
Solução escolhida
We at TronicsFix just posted the teardown for this a few days ago: CUH-1200 Teardown
I hope it helps!
Esta resposta foi útil?
Pontuação 13
6 comentários:
I finally bought the power supply for the cuh1215a model is this the same way to open the ps4
por
To replace the power supply you just need to remove the bottom plastic. Then the power supply will be right there under it.
por
Well done TroncsFix. This is the way to SPAM and help others at the same time, very acceptable ;-)
por
Not sure how you consider this spam. Posting a teardown of the newest model PS4 seems like a pretty helpful thing to do. Was there somewhere in this teardown that we put links to anything of ours?
I think comments on these questions are better if they bring value to ifixit visitors, I'm not seeing how yours does.
por
Would a T8 torx work instead of T9?
por
Exibir mais 1 comentário
My ps4 the HDMI cord was pulled out so i tryed other ones and for some reason it dont want to work the box it shelf does come on cuz the blue light comes on but for some reason on the tv it dont idk what to do
Pontuação 0
1 comentário:
Does the light ever go to white?
por
Adicionar a sua resposta
Dave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 43
Últimos 30 dias: 166
Duração total: 34,441
