Ir para o conteúdo principal
HP Part#: CN731A#B1H: Printer, scanner, copier, web browser with wireless internet capability
16 Perguntas Visualizar todos
Pergunta encerrada
After reassembling, printer won't turn on
After following the HP Photosmart D110a Scanner Glass Replacement tutorial and reassembling, the printer won't turn on.
All wires were reconnected and the power button face was reinserted.
I was not grounded when I disassembled the printer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Disassemble the printer as you did when replacing the glass, there is a small cable that you need to make sure is connected properly. Recheck all flex cables. Being grounded will not short the printer out. Test outlet also with a lamp, be sure outlet works.
Matthew Lucas
Esta resposta foi útil?
Pontuação 1
1 comentário:
Rechecked flex cables and tried a different outlet. Printer powers on again.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 149
