Ir para o conteúdo principal
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
Why the screen won't light up
The kindle is charged the green light comes on but the screen won't light up
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I would see if you can see anything on the screen when you get it into the light just right you will need to use a bright source of light if you can then it is a back light issue. if you can not then the problem is ether the screen or the the device itself.
Esta resposta foi útil?
Pontuação 0
1 comentário:
the background picture is on but the reading light won't come on. When I push the button to turn the reading on, the green dot lights up for approx 5 sec. and then shuts off while I'm holding the button in.
por
Adicionar a sua resposta
Felicia Mcfarland será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 425
