Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Perguntas Visualizar todos
My right trigger thinks I'm holding It down
My right trigger thinks I'm holding It down. I think my hall effect sensor is broken but I know nothing about those
Esta é uma boa pergunta?
Pontuação 10
2 comentários
mine does this too! when I press the button down it doesn't work but when i'm not pressing it thinks im pressing
por
Its doing that to me to i'm just going to get a whole other controller.
por
Adicionar um comentário
4 respostas
Solução escolhida
my son cleans his PlayStation controller with isopropyl alcohol and compressed air . As he puts it the oil from his sweaty palms seeps down into the controler and gums up the works , so what he does is runs a little isopropyl alcohol into the controler buttons and joysticks , then blows them out with compressed air. Cleans out the oil. Hope this helps
Esta resposta foi útil?
Pontuação 2
1 comentário:
should mention if the controller stick is loose or moves too freely then the piece is just broke and this wont help
por
I have the same problem, I think maybe can solve this by getting the hall effect sensor from another controller, or maybe take the sensor of the other trigger and cut it in two pieces and put each part in his respective place.
Pontuação 1
Same it is very annoying
Pontuação 1
I really don’t know how to stop it sorry
Pontuação 0
Adicionar a sua resposta
bzachhuff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 59
Duração total: 39,168
