Ir para o conteúdo principal
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
432 Perguntas Visualizar todos
Pergunta encerrada
Stuck in a Bootloop what can I do?
Hey guys,
My current problem is that my imac stucks in a Bootloop somehow.
One Day it just went down and since then the imac stucks in a Bootloop.
I tried to start the imac in safe mode, even a start from a bootable USB didn't work.
I also Tried to boot from a CD and everything didn't work.
Maybe smth overheated because the day were the imac broke down was a really hot day.
Thanks for Answeres.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Check the optical drive and see if a disk is in it. If not open the machine and disconnect the hard drive. Next insert your original system installation disk and see if it will boot. Here's how: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks i will give it a Try
por
Review this Apple T/N: About the screens you see when your Mac starts up. Can you tell us which screen it restarts at? Also see if the T/N offers a solution and give that a try.
You may also need to find a cooler location to use your system. Once it starts up normally, you may want to install a good temperature monitoring app like: Temperature Gauge Pro it may help you isolate the reason why the system is having problems.
Pontuação 2
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 364
