Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3531 Perguntas Visualizar todos
Ear speaker replaced and still very low volume
I just replaced the ear speaker on an iPhone 5S because of very low volume. Install went smoothly, speaker port is clear and the black gasket is in the correct position, still very poor volume from the ear speaker. Everything else on the phone works fine, any ideas what else could be causing this problem? Thanks
Update
Been trying to fix this and I finally found something that worked:
Settings---General---Language & Region
scroll down and change the language to English (UK)
Exit settings
Go back in a change language back to English (US)
I found this solution online, and I thought there is no way this can do anything. My wife's phone now works fine, the volume for the ear speaker is back to normally. Any idea's on why this did anything?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
5 respostas
Solução escolhida
Assuming you have tried increasing volume within a phone call you can take it apart and remove the ear mesh glued to the screen where the ear speaker attaches to. It will look as a hole instead of having that dust protector. If that works you can buy that little piece and add it later on. It is common for that ear mesh to get so dirty or something spilled on that would block the sound :)
Esta resposta foi útil?
Pontuação 5
5 comentários:
Yes, saw this advice in a few places and just tried it. Voila! Eureka! Yeah, it worked. I didn't remove the mesh though. I removed some mesh or something from the black rubber part and scraped the mesh on the frame with my tweezers and brushed it with a tooth brush. Was tempted to put alcohol on it but decided against it.
por
sweet! you can actually buy that part or leave it off :) glad it worked!
por
How can I remove the mesh without opening the device
por
You cant! You have to open the device and do it the right way!
por
Late to answer but I used a soniccare toothbrush to vibrate the dust out and it instantly sounded better. Just a thought for all the new iphones that are a pain to open.
por
In the "settings" - "general" - "assist" and shut down telephone noise elimination. You can try it.
Pontuação 0
You can try to Change the way in holding the phone or turn up the volume when you are calling.
If the voice still very low, take it to the repair shop.
Pontuação 0
I tried the English UK thing but it didn't work at first.
It only worked after I set it to English UK and restarted my phone and then changed it back to English US and restarted my phone.
After the restart when I changed back to English US my 5c is loud again.
I also took a qtip and cleaned the gunk out of the ear speaker and got even louder sound.
My qtip was black on the end.
I used alcohol on the qtip.
Don't understand the fix but by golly it works.
Pontuação 0
Some users reported that the sounds from their call volume are too low and some are totally not working.FInd out how to fix Low call Volume on iPhone.
Pontuação 0
Adicionar a sua resposta
coug52 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 35,989
