Ir para o conteúdo principal
Device and repair guides for the gaming and high-performance laptop computers in the Dell's XPS (Xtreme Performance System) line of products.
356 Perguntas Visualizar todos
Pergunta encerrada
Not able to hear properly from one speaker. How to fix it?
Hello,
I am using Dell XPS 15 L502X laptop. I am not able to get clear sound from my laptop speakers. It feels as the sound is coming from one speaker and connection is broken from the inside. Can anyone please tell me if it is possible to check the connection of the speakers to the motherboard and how?
Thank You
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
To ensure this isn't a settings issue, go to Control Panel - Hardware and Sound - Sound. Under the playback tab, select your speakers and click configure, then click test. It should play sound from both sides regardless of how they are set up in Windows.
If both speakers function well on the test, you will need to adjust the balance of your speakers.
If you still don't get sound from both speakers during the test, you will need to disassemble your computer (if a guide is not on iFixit, you should be able to find one somewhere online), find which speaker is broken, and follow the wire to the motherboard where it should be firmly connected. If it is not, plug it in and test the speakers again. If it still doesn't work, you will need to buy a replacement speaker.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 191
