Ir para o conteúdo principal
Repair guides and support for tablets made by Visual Land, Inc.
How do you replace visual land prestige elite 9q touch screen?
I bought a new digitizer touch screen for my visual land prestige elite 9q tablet, but I do not know how to replace it. I looked for the two screws, but I cannot find any screws to replace this screen. If you know how to change it out, please tell me step-by-step how to change it out.
Thank you!
Esta é uma boa pergunta?
Pontuação 4
1 comentário:
corrinestone, take a couple of high res images of all the sides of your tablet. Post them with your question by using this guide Adicionar imagens a uma pergunta já existente That way we can see what you see.
por
Adicionar um comentário
4 respostas
I'm looking for the same,
My screen had few
L out in 3 weeks and it cracked and they,won't replace it
Esta resposta foi útil?
Pontuação 0
How and were can i get a scereem foe a 10 inc visio land tablet
Pontuação 0
1 comentário:
I would try Walmart or vision land' if youet one through Walmart and it messes up within 14 days they will replace it'
por
Does no one have the answer to this question? I am having the same problem. My Grandson accidentally cracked the screen on my prestige elite 9q tablet and I have opted to change it out myself. I am wondering if it opens like a cell phone? Do you just go around the edges and pop it? There are NO SCREWS in this thing!
Update (08/29/2017)
I HAVE THE ANSWER! The tablet pops apart like a cell phone. CAUTION: Remove any SD cards before attempting this. I didn't and broke mine. Fortunately, there was nothing lost. There is a small slot on the left hand side of the tablet across from the on/off button.
Sorry if these pics don't show up. I'm new here. I used a nail file to start, then a flat head screw driver. (The only things I have.) Be sure to pop the front cover and not the back. The front is more flexible and easier to pop the tabs open. That is as far as I've gotten. I suggest YouTube videos for the rest.
Pontuação 0
You must be very careful, its more complicated that it looks,
Go to YouTube, it will show you how,
There's 2 screens, ones a touch screen and then the monitor,
You must also remove the monitor, carful that you dont crack it,
Everything comes out, also be careful of the speaker wire it can snap off,
You must pry off the outer casing very slowly, remove all screws on the inside, there's only 2 maybe 3.
The monitor will be the hardest to come out,
The touch screen connects to the component sheet inside, careful not the bend or crack the wire connector, else you will need another touchscreen
Good luck
Be sure to watch the video on how too
Some dont have screws on the outside...
Pontuação 0
Adicionar a sua resposta
corrinestone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 1,134
