Ir para o conteúdo principal
Pergunta encerrada
iPhone 5 searching for carrier signal all the time..!
Ocassionally there is some signal but only for a very short period of time: after 10-15 minutes it goes back to searching... I have tried everything already - I reseted the network settings, all settings, made a hard reset, installed updates, tried different SIM-cards..! It does not matter what I do, nothing changes. I already googled for two days straight and I have not found a clue whatsoever! Is it possible that somehow the antenna inside the phone is broken?? If yes, is there something I could do to fix it? Thank you very much for your answers!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You could go forward and order a new iPhone 5 antenna, they are really cheap and like any other phones antenna they can burn and stop working properly.
iPhone 5 Cellular Antenna
Imagem de iPhone 5 Cellular Antenna
Produto
$9.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
is there any way to find out if the antenna is really burned or damaged/do you see it?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 142
