Black screen and beeps when charging after battery replacement
Hi,
I know I'm not the first with this problem but I red all other questions and unfortunately nothing helped in my case...
So I replaced my iphone 5 battery with a new one (ordered on iFixit), and when I try to start the phone, nothing happens, the screen remains black.
Then I plugged it to a charger, and it started to beep (or vibrate in silence mode) every 10 seconds approximately.
Then I looked in ifixit for same problem, so I :
- checked all connector then reassemble the phone
- disassemble, disconnect and reconnect the battery, reassemble the phone (I tried it 3 or 4 times)
- try with the old battery
- try to clean each connector carefully
The phone is displayed in iTunes when plugged in and charging correctly.
The connectors don't seem to be damaged :
Do you think that I maybe damage something on the screen connector cables during my first opening ?
Indeed the screen came up a little roughly...
Is there any way check it ?
Thanks in advance
Steph
Esta é uma boa pergunta?
