ASUS X550ZE-DB10 15.6-Inch laptop doesn't touchpad work after login?
I recently purchased a new ASUS X55OZE with windows 8 from amazon. Today I performed a clean install of Windows 10 on the device (I didn't make a backup because I had nothing saved on the computer). The install seemed to go smoothly, but now when I start up the computer, the touchpad will not work after the login screen. I tried looking in the touchpad and mouse settings to see if it had been disabled, but there was not option to enable/disable the touchpad, only to adjust its sensitivity. I'm pretty lost on where to go from here. I would try to reinstall the touchpad drivers but I can't figure out how to do that without use of the touchpad!
Esta é uma boa pergunta?
3 comentários
Hi I'm having the exact same problem! Not sure if it is a missing driver or just a bug from the new system. I really need advice on this...
por Cris
Thank you for your help! We had a look at the touchpad drivers and found that there were two sets of them installed. By disabling one of them it started working properly again.
por Cris
hey @Cris I'm having the same problem, could u help me??please
por mueezalgabel
