Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Perguntas Visualizar todos
The X button Doesn't Work.
The X button (not the guide button) on my controller does not work; however, every other button does work. Which motherboard do I need to replace to fix this problem?
Esta é uma boa pergunta?
Pontuação 3
7 comentários
Hello, Has anyone gotten any answers on this matter? As of now this is part of an issue I am having with my controller. Should I call XBox for assistance?
por
same thing has happened to me aswel… i was not bothered to much i just rerouted X to the bottom back paddle.. now the kids have broken the shells so gonna re do all the parts.. I really want to know aswell if the X button is a hardware or software problem
por
It also happened with my controller from the xbox one s. Got it connected to the iPad Air and played Genshin impact. Suddenly the X button stoppend working. Connected it to my xbox and it si somehow overly sensitiv. instead of moving one tile it moves two. Updating the controller firmware did not do anything. Problem is the same. I can not point out if it is a hardware or a software problem. I only know firmware update does not cure the controller.
por
mine is the Model 1708 so it seems to be a general issue
por
the same thing happened to me but im still trying to figure it out
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
Have you tried cleaning the membrane (the rubber thingy with the buttons on it) and the motherboard?
Esta resposta foi útil?
Pontuação 1
Take a screwdriver and press the button as much as you can i did it and it worked hope this helps
Pontuação 0
Adicionar a sua resposta
Turner747 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Duração total: 12,569
