Ir para o conteúdo principal
Samsung Galaxy smartphone featuring a large display , and large font size.
49 Perguntas Visualizar todos
I'm only getting the samsung logo and phone is not working anymore
My phone went black then i tried to charge it and after charging, it would no longer turn on. All i'm getting is the Samsung Galaxy Grand GT-I9082 logo. I tried to remove the battery and turn it on/off a dozen times already but still the same result.
Is there a way to back up my data in the phone should i need to reformat it?
Please help.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I have the same problem but with my Samsung Galaxy Tab 2
por
Adicionar um comentário
1 resposta
Pergunta mais útil
When smartphone freeze before standby mode it means it has software or booting problem . All you have to do is flash it with newer firmware then your problem will be solve. Only do if you are what are you doing because miss handling can lead to brick your device.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
kiddlez75 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 872
