U2 IC Charge chip replacement! Please help!
Hello again ifixit.
Im just learning how to do BGA work and micro soldering and such. I had a quick question of replacing the U2 IC on an iPhone 5s, how do you go about lining up the new chip? It doesn't seem to want to sit correctly on the board connections, it keeps sliding to the side when I go to heat it up and if I put pressure on it, it immediately slips. Is there someone to clean up the board connections after removing the old chip? I had tried using desoldering wick to clean them up, but on a board i have tried that on before, it ended up pulling a couple of the connections away from the board. And I don't want to do that as it seems impossible to get solder to form another connection in those spots now.
I guess basically what I'm asking is, how does one clean up the U2 IC connections after removal of the old chip, and then how does one line up the new chip without crossing connections? It seems in most instructional videos, they skip the part where the clean it up.
Any help is greatly appreciated!
Esta é uma boa pergunta?
