Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
Controller won't sync with console.
I've run into an issue with a few PS4's where the controller won't sync with them. I know the controller I'm using is good because I've used it on several different PS4's without issue. Has anyone had any luck fixing this issue?
Thanks
Esta é uma boa pergunta?
Pontuação 2
2 comentários
When I plug the controller in and I press the PS button the light on the controller flashes blue, but it never connects. The light will go back to orange and then just repeats the process when I press the PS button again.
por
this is literally happening to me too but i am inexperienced with welding or whatever you guys do so i cant really fix this
por
Adicionar um comentário
1 resposta
Solução escolhida
I managed to change the wireless communication chip on the motherboard and it fixed my problem. In this picture it is in the lower left hand corner covered by a white sticker and shield.
Esta resposta foi útil?
Pontuação 1
5 comentários:
So you must have reballed it by hand?
por
I didn't even reball it actually. There are only about 60 contacts on the back of the chip and they are spaced far enough apart to not have to reball. I just fluxed the back of the chip that I took from another PS4, put it into position, heated it and it worked like a charm.
por
Wow..crazy...I assumed you would have to reball it. Nice! Hopefully it lasts a long time!
por
Soooo.....? Success??
por
how am i an inexperienced 14 year old gonna fix this
por
Adicionar a sua resposta
RegencyTech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 19,048
